Tractor Talk Discussion Forum
1944 case sc zenith carb
jamey
04-04-2006 17:38:22
i have this carb from a case sc and it has a bunch of numbers on it . on the bottoom of the bowl it has a b5 and on the top part were it bolts to intake/exhast manifold it has a 14 on it and this round metal tag that has a mixture of numbers and letters. so if you have any ideas what the numbers are that would be a great help. or if you know were i can get a bracket that holds the floats is broke. so if you know any one who has parts that would help
Glen in TX
04-04-2006 21:11:26
 Re: 1944 case sc zenith carb in reply to jamey , 04-04-2006 17:38:22
Probably a Zenith 11535 or 14991. 267J8 model series carb. Case # was 09658AB. The bracket the float pin goes in is broke? Can't get that seperate and will have repair or make it or find another carb. If it's just the float you can get new floats and carb kits.
streaker
04-04-2006 17:49:17
You usually use the numbers on the round metal tag, usually brass, for identification.
