Tractor Talk Discussion Forum
Re: International 300 Utility
TDK
04-03-2006 18:52:59
That's most likely hyd. oil leaking. The power steering uses the oil from hyd. system and there's a plug you can unscrew under the seat cushion to check hyd. level.Does your 300 have independent or trans. driven pto ?
jenglin34
04-03-2006 18:55:24
 Re: International 300 Utility in reply to TDK, 04-03-2006 18:52:59
I would assume an independent pto, I'm not for sure. I'll check out the plug. Thanks
TDK
04-03-2006 19:47:33
 Re: International 300 Utility in reply to jenglin34, 04-03-2006 18:55:24
Jim, the IPTO is engaged by a long lever on the right side of seat. Trans. driven is engaged by a rod behind seat near rockshaft.
