Tractor Talk Discussion Forum
tractor model
texasme
03-31-2006 06:43:08
i have a harry ferguson tractor,serial # 25711.what type is it,te20,to20.and so on.I need a starter for it.It has been converted over from a 6 volt system to a 12 volt.Any starters out there?
Irv (Ia)
03-31-2006 13:34:35
 Re: tractor model in reply to texasme, 03-31-2006 06:43:08
According to the serial mo's at left, you got a 1950 TO-20. The motor block on the left side should say Z-120.
Irv
Jim.UT
03-31-2006 07:58:41
A 5 digit s/n in that range should be either a TO-20 or TE-20. I've not spent a lot of time around Fergusons, but the ones I have looked at had a "TO" stamped on the s/n plate above the steering column. I assume the TE models would have a TE stamped there instead.
