Tractor Talk Discussion Forum
Case 430 vs. Ford 4000
Paul L
03-29-2006 13:49:19
What one's the better tractor, a Case 430 Disel or Ford 4000 Gas? Both are loaderless. I have the two, and am going to be getting rid of one. Would be looking at bush hogging, snow blowing with one of them. Any thoughts? Paul
Dachshund
03-29-2006 18:23:16
 Re: Case 430 vs. Ford 4000 in reply to Paul L, 03-29-2006 13:49:19
Ford, hands down!
BobMo
03-29-2006 18:01:14
Paul, why don't you keep the one you like the best? I know this may not sound reasonable but I think it is..... ....
Paul L
03-29-2006 20:08:54
 Re: Case 430 vs. Ford 4000 in reply to BobMo, 03-29-2006 18:01:14
Bob,
It's probably going to come down to that, no matter what anyone says - wanted some different thoughts though. No point in driving a tractor I don't like. The Case I bought about 2 months about and have enjoyed it immensely. But, the Ford I have the loader arms for and just have to add the hyraulics and would have myself a loader tractor. So . . . it's still up in the air. Paul
MF Poor
03-29-2006 15:53:26
The 3 cylinder Ford 4000 was one of the best tractors Ford ever cranked out. Torque galore. 4 cyliner version wasn't all that bad, but no match for the later model 3 banger.
430 Case was a good tractor, but certainly no match for either Ford IMHO. (Had a 430 years ago)
Bob N.Y.
03-29-2006 15:30:46
Is the 4000 a 3 cylinder or 4 cylinder? I think all 430s had either Live or Independent Pto. Does the 4000 have one or other? In spite of what some might say, that is imperative for running a snowblower.
Paul L
03-29-2006 16:20:18
 Re: Case 430 vs. Ford 4000 in reply to Bob N.Y., 03-29-2006 15:30:46
Bob,
The Case 430 I own now, and it has something like a live but not quite. Case built them with a hand clutch/mid mount clutch, allowing you to pull up on it, stop the tractor, clean out the snow blower and continue on snowblowing. The 4000 I'm picking up in about 2 weeks, was a real good deal, and according to Tractor Data, has an independant clutch. Couldn't tell you whether it was a 3 or 4, but will keep what was said in mind. Thanks for the info Bob.
Paul L
03-29-2006 16:22:53
 Re: Case 430 vs. Ford 4000 in reply to Paul L, 03-29-2006 16:20:18
By independant Clutch I meant PTO. Is what I described the same as independant? Just thought of that, and didn't realize that's what it was called.
Bob N.Y.
03-30-2006 05:48:58
 Re: Case 430 vs. Ford 4000 in reply to Paul L, 03-29-2006 16:22:53
Your Case has Live Pto. That means you can stop and start the ground travel without interupting the PTO. A 4000 with IPTO would hve to be a 3 cylinder, 1965-1974. The 4 cylinder 4000s, 1963 & 64, were available with Live but not Independent. IPTO allows you to engage and disengage the PTO without interupting the ground travel as well as the other way around.
