Tractor Talk Discussion Forum
cracked block.
ken Farmall
03-28-2006 16:31:42
I have a Farmall H, with a cracked block, it has a hairline crack about 4 inches long in the middle of cylinder # one. My local machine shop suggested I glue the liner in, has anybody done this, and does it work. Ken.
the tractor vet
03-28-2006 17:01:41
 Re: cracked block. in reply to ken Farmall, 03-28-2006 16:31:42
Well they must not be a vary good machine shop with that info . The way we have fixed this problem is to bore that hole out and install a thick wall repair sleeve and then bore it to take the replacement sleeve for a correct fit have done many that way .
raytasch
03-28-2006 17:00:41
Bore and install a sleeve in a block is common machine shop proceedure. Works good, last a long time if done right.
ray
