Tractor Talk Discussion Forum
Lo-Boy 185 hydraulics question
MeAnthony
03-27-2006 15:45:07
The live pump is rated at 1550 - 1600 psi. It operated the 3 point and the mid-mower deck (both one way). I have a loader on the tractor, but I'd prefer to tee in to the live hydraulics rather than use the pto-driven pump(which is actually supposed to run the loader). There is no tag on the pto pump, so I don't know the output psi. If I do splice in to the live pump lines to run the loader, will I have sufficient pressure? Or will I be overworking the live pump?
Thanks for the responses,
Anthony
K-Mo
03-28-2006 06:43:42
 Re: Lo-Boy 185 hydraulics question in reply to MeAnthony, 03-27-2006 15:45:07
You have enough PSI but not enough pump capacity (Gallons Per Minute, GPM). Think about how fast your 3-Point and mower raise when one cylinder is supplied. On a loader you will have two lift cylinders and at times two more bucket cylinders to supply.
I have an I-240 with a loader that I need to install a separate pump on for the loader. Now, when using the tractor pump, beside being very slow, the loader will drift down if I try to raise and tilt at the same time.
