Tractor Talk Discussion Forum
1586 gearing optionS??
Dave from MN
03-26-2006 14:39:27
wHAT DID THE 1586's a'l come with for transmissions. I have looked at one with High/Low and 3 speeds and a T/A, today one had a High/Low and 4 speeds with T/A. WHat other options are out there and which is better. Are they all sync'd.
ed1
03-27-2006 10:06:34
 Re: 1586 gearing optionS?? in reply to Dave from MN, 03-26-2006 14:39:27
Never had one or sat in one but I thought the big guy had a V8 and a 3 speed. Also thought they changed the numbers around like 1568 for the V8 and 1566 for the 6cyl. Can't remember what they did with the 86 series though.
edchainsaw
03-26-2006 19:04:22
we had one it was a 3 speed with high low and TA (well part time ta)
but I never saw one with the 4speed.. I saw some of the Wester specials and never saw one with a 4speed either but I knew they were differnt than the original 1586's.. even the motor was a bit differnt we always wanted one... but ours was so much a piece of junk we just gave up on anymore IH's
the tractor vet
03-26-2006 19:03:38
All 1566-1586 were three speeds , now i have never been in one of them as we did not have but a few floaten around here . Now i have heard of guys swapen out the speed trans with a 14 as they did not like just three speeds and wanted a couple more gears to chose from it is not a hard swap but myself i would be a littel learie of the trans as from what i have seen when you twist the screw and get to many ponys up ft. the gears in the speed trans suffer as most of the 1466 and 86 that i have had apart that were turned up 1st 2nd and 3rd are hammered , even my buddys 1066 the gears were starten to round over from being turned up . So look at the rear end as they are larger then a 1486 , but i think someone put the 4 speed in .
ncdiesel560
03-26-2006 17:01:40
My 1086 has a four speed but am not sure on the 1586. Id check the serial number.
RickB
03-26-2006 16:28:30
No 4 speeds and no synchros.
rdk mo
03-26-2006 15:23:24
The 1586 came out with 3 speed High and low with the TA. None came factory 4 speed. rdk
Dave from MN
03-26-2006 16:41:31
 OK so what could it be? in reply to rdk mo, 03-26-2006 15:23:24
third party image
????? Well then I wonder what is up with this one. Maybe I better run the serial # and see if it is an imposter. The shifter was left of the seat on the fender well. Had Rev-Nuet-low-high( beleive that was the order) then next lever in had 1-2-3-4. The TA was on the dash on the left side. I am really confused now. Does this set up sound familiar for another tractor? It is labeled as 1586 and looks like a 1586.
kj(SE IL)
03-26-2006 16:53:46
 Re: OK so what could it be? in reply to Dave from MN, 03-26-2006 16:41:31
dad had one of each and other than the decals the way he bought his you couldn't tell at a glance any difference. kj
kj(SE IL)
03-26-2006 17:03:19
 Re: OK so what could it be? in reply to kj(SE IL), 03-26-2006 16:53:46
meant to add could it be 14 with 15 decals?
