Tractor Talk Discussion Forum
pop starting
chris sweetland
03-26-2006 13:55:19
ive taken to pointing the nose of my tractor downhill to pop start it as my battery is getting weak will this wear anything funny or damage anythin over a long period? thanks chris
Leland
03-26-2006 20:57:45
 Re: pop starting in reply to chris sweetland, 03-26-2006 13:55:19
I have helped replace a couple of broken cranks from people doing that before .
Crem
03-26-2006 18:29:39
We did it a zillion times back in the 60's with a TO-20 Ferguson. We also cranked it a lot. We couldn't afford a new battery back then. Start it in third gear unless there is very little downhill grade and then use fourth gear. We could push it by hand on the level and start it. I still have the tractor now, but usually have a good battery. :o))
chris sweetland
03-26-2006 16:53:28
its a to-20 i am on my driveway (paved) and if i hit the bottom of the hill i have 100' before the pond and i just did a brake job on it so i should be ok
KEH
03-26-2006 17:21:41
 Re: pop starting in reply to chris sweetland, 03-26-2006 16:53:28
Should have no problem if you do like old said. Having a paved road is a huge advantage.
KEH
KEH
03-26-2006 15:49:30
If the tractor is a diesel it wont start good by pop starting. BTDT. Years ago I tried to start my almost new tractor this way in cold weather and wound up heating cans of new oil and changing the oil at the bottom of the hill. Started fine then. (this was in cold weather) Turned out the factory battery was defective. Replaced battery, no more serious trouble starting. Another trick for cold weather starting: get an electric heat gun, use it to warm up air intake manifold, then have someone blow the hot air into the intake manifold while you crank the tractor. Don't use a propane torch for heating for obvious reasons.
KEH
old
03-26-2006 14:47:20
You will not hurt a thing doing so unless you drop the clutch hard. Or in other words you need to let it out the same way you do when driveing it. The wear on the clutch will be the same as if you are driveing it around so it doesn't hurt the clutch
John Hajek
03-26-2006 14:27:15
$60.00 battery===== =$1600.00 clutch job.your tractor.
Ole/Mn
03-26-2006 14:22:01
If its da reglar gear transmisun it aint gunna hert nuthen cept yer dignity if ya fergit da sientifik faktors. How long da hil, how steap da hill, how miny trees at da bottum an if da braks werk
F40Man
03-26-2006 14:28:09
 Re: pop starting in reply to Ole/Mn, 03-26-2006 14:22:01
I agree with Ole/Mn but want to add just one more thing, besure the grass isnt wet if your not on dirt or you will be in for a good slide and without a sled too.
