Tractor Talk Discussion Forum
Early Morning Question
Allan In NE
03-25-2006 03:36:50
Here's one for ya,
How do you tighten the throttle lever on an IH Hydro 70?
The "over-center" linkage spring on mine works to hold good while either at idle or wide open. At any position in between tho, it will slowly 'creep' back to idle over time.
There must be a friction clutch somewhere under the cowl, right?
Thanks,
Allan
izzap
03-25-2006 04:42:15
 Re: Early Morning Question in reply to Allan In NE, 03-25-2006 03:36:50
Right
IaGary
03-25-2006 04:41:55
Mornin Allan
I don't believe there is a tensioner on those.
Buttttt usually those things get so stiff your trying to figure a way to loosen them.
If I leave my tractors with that type of cable outside I have to oil it next time to free it up.
Now maybe if you squeeze the tube a little where the cable comes out it will tighten it up a little.
Otherwise if its like my 86 series I don't know.
Just wondering if theres anything on the shaft where it goes thru the pump?
Gary
Leroy
03-26-2006 06:19:52
 Re: Early Morning Question in reply to IaGary, 03-25-2006 04:41:55
I don't know anything about those tractors but see that you mention a pump so it makes me think you are talking deisel while Allan,s tractor is a gas. Am I correct?
IaGary
03-25-2006 05:10:44
By izzap's reply I take it the set up is differant than what I thought so disreguard my response.
I engaged fingers before I thought.
Gary
