Tractor Talk Discussion Forum
Different Tractors - Need some input before buying
Paul L
03-24-2006 12:35:38
Heading to an auction tomorrow and wanted some input on the following tractors. Ford 6640 with loader
John Deere 2355 with loader
Case 480C with loader
Case 990 with loader
Does anyone know the HP rating for each? I'm leaning towards the Case 990 or John Deere. Thanks, Paul
Langoley
03-24-2006 16:15:31
 Re: Different Tractors - Need some input before bu in reply to Paul L, 03-24-2006 12:35:38
Personally I would lean away from the 990 as it doesn't have a "sleeved" engine.The 480 may or may not have a 3 pt. and pto,either one of the other two would make good tractors depending on condition and price.
JDknut
03-24-2006 15:49:49
Any one of those would make a good choice, depending on age, condition, quality of loader and price. They are all a little different in HP, tho. The Ford is about 76 PTO HP, whereas the Deere and Case 990 are similar at 56 and 52 PTO HP respectively. Not sure about the Case 480C. I believe that is a construction machine, probably in the 50-HP class. The "Case" 990 is essentially a post 1974 David Brown 990 which is a good tractor, but the price for the one in your other post seems a taste high. I have a Deere 2350 which is essentially the same tractor as the 2355 so I tend to be biased in that direction, but like I said before, all things being equal, you won't get hurt on any one of those assuming all in good condition.
Paul L
03-24-2006 13:32:36
Found if on the web. Take a look and tell me if you think it's a fair price.
Paul L
03-24-2006 12:44:51
If anyone has pictures with a price that the tractor would bring in, it would be great to.
