Tractor Talk Discussion Forum
Which Transmission Oil ??
Canadian Rick
03-21-2006 04:18:09
Very Interesting reading. I have a MF 65 with a loader. One dealer tells me to use Trans Hydraulic oil the other tells me to use MF SAE 90 as stated in the manual because the Trans Hydraulic will ruin the seals in the older tractors. Who is right? What is the best choice?
souNdguy
03-21-2006 06:06:11
 Re: Which Transmission Oil ?? in reply to Canadian Rick , 03-21-2006 04:18:09
Wow.. what advice.
I've not much exp with MF.. but have messed around with fergy's.. and have plenty of fords.
Right now.. if you walk into a CNH dealer and ask for tranny oil for an 8n.. they hand you the 134d UTF type oil ( transdraulic. ). That oil was originally 90wt mineral oil.
Now.. here's a tricky part. Early ford 9/2/8 N and some fergies had a belly pump that could handle the 90wt oil.. However.. most newer pumps.. including the pump on the 53 naa.. and most power steer / loader pumps don't like the hi-viscosity oil.. but like something thinner itn the 10-20-30wt range.. like aw 32/46 or the trans draulic oils in the 10-20-30w range.
Though i don't have specific info on your machine.. I'd lean toward that loader.. if it uses a stinger or engine mounted pump.. that it needs the thinner utf oil. And I've never heard of a utf oil eating the seals out of old machines... or there'd be aloto of 1939 9ns with no seals..
Soundguy
