Tractor Talk Discussion Forum
70 wheatland (John Deere)
Roy in Mo.
01-17-2006 11:14:49
Would a 70 wheatland with 3 pt. be worth a lot more than one wihout? How much more?
BILL IN SOUTH WALES
03-20-2006 12:32:04
 Re: I have a wild idea just not sure how to set it in reply to old, 03-20-2006 11:59:27
AIR FROM AN AIR COMPRESSOR WONT DO IT,PRESSURE IS NOT HIGH ENOUGH.A GREASE GUN CAN PRODUCE THOUSANDS OF PSI.AIR COMPRESSOR A COUPLE HUNDRED AT THE MOST.
Nebraska Cowman
03-20-2006 15:30:38
 Re: Chains and binders for hauling tractor under 5 in reply to Wayne in TX, 03-20-2006 15:22:27
I don't remember, some place out of Ohio I think
I Bleed Green
01-17-2006 15:43:26
 Re: 70 wheatland (John Deere) in reply to Roy in Mo., 01-17-2006 11:14:49
3 point is rare on any standard, so i say yes its worth more if it has one. The same goes for PTO. Allot of standards dont have a PTO
Don Wadge
01-17-2006 16:13:28
 Re: 70 wheatland (John Deere) in reply to I Bleed Green, 01-17-2006 15:43:26
That is a gross misconception. Almost all "Standard" tractors came with a factory PTO. That would have been true of many standard tractors into the 1930's, but from then until 1960 or so practically all "standard" tread tractors were equiped with PTO. Somewhere in the early to mid 60's PTO on larger standards started to disappear as there was no longer much requirement for them. I think that most of the smaller to mid-size "standards" continued to be purchased with PTO as they were used for rotary mowers and snowblowers etc. Belt pulleys disappeared somewhat earlier- mid 50's.
jubilee johnny
01-17-2006 13:17:29
Do you think it would matter if it were a factory 800 series vs aftermarket such as the one currently on ebay item #7582358644. That's a good looking tractor.
Roy in Mo.
01-17-2006 12:19:22
I should have stated 70 standard instead of wheatland,sorry
Don Wadge
01-17-2006 16:00:33
 Re: 70 wheatland (John Deere) in reply to Roy in Mo., 01-17-2006 12:19:22
Ata Boy. We'll get you corn guys sayin' it right yet. Have a good day.
buickanddeere
01-17-2006 14:29:29
Wheatland is another name for the standard chassis. The standards could be ordered with an adjustable front axle as well. The rowcrop chassis can be had with a single, dual narrow, rollo-matic dual narrow, a 38" wide, and adjustable round tube or square tube wide.
