Tractor Talk Discussion Forum
ser ## need help to find
art#1
01-15-2006 11:24:18
hello! i just got farmall c would like to if there is any other place on tractor that ser# would be found. can not read ser# plate on side of seat houseing would like to know year?? found part # s on tractor 351132R-1 ?? if that would be any help. thanks for any help!!
TDK
01-15-2006 21:30:56
 Re: ser ## need help to find in reply to art#1, 01-15-2006 11:24:18
The engine serial number is on a pad on the right side of engine just below the #1 spark plug.
earlschieb
03-22-2006 21:06:52
 Re: vac case tractor in reply to Jennifer Clarke, 03-22-2006 19:59:40
This site says that it is a 1944 model. As far as worth, you would need to post a picture, and tell us about how it runs, mechanical problems, and how it drives. Most Vac tractors around here are not worth much more that $1000.00, or even less.
Case Model B, C, CC, CI, CO, R, RC, D, DC, DI, DO, LA, LAI, S, SC, SI, SO, V, VC, VI, VO, VAC, VAH, VAI, VAO, and W
[ Return to Models] [ Return to Main List]
Year Starting Serial Number 1929 300201 1930 300301 1931 300401 1932 300501 1933 300601 1934 300701 1935 300801 1936 300901 1937 301001 1938 4200001 1939 4300001 1940 4400001 1941 4500001 1942 4600001 1943 4700001 1944 4800001 1945 4900001 1946 5000001 1947 5100001 1948 5200001 1949 5300001 1950 5400001 1951 5500001 1952 5600001 1953 5700001 1954 5800001 1955 5900001 1956 6000001 The Serial Number is located stamped on a name plate fastened to the instrument panel for most Case tractors. Can also be on toolbox
