Tractor Talk Discussion Forum
Belly grader for 1959 310B
fallon in ct
01-11-2006 08:32:19
I picked up a 1959 310B with a loader and backhoe this summer. After purchasing it I was told there was some other "stuff" to be picked up that went with it. Aside from the spare tires was a belly grader setup. I've asked around but have had no luck getting any literature on how this hooks up. The loader controls have a set of three spools mounted above them for this grader. The utility backhoe looks to be a "quick release" of sorts. It mounts at four points onto a wrap around mount plate which has two guide pins. Another thing I found when I got it home was what looks like the swing arms for a three point hitch setup under the footrests of the backhoe. Does anyone know where I could possibly find manuals for this implement? I'll try to get some pictures posted soon. Thanks for any info.
Scott
Farmall Don
01-11-2006 09:18:05
 Re: Belly grader for 1959 310B in reply to fallon in ct, 01-11-2006 08:32:19
I've been trying to find the same for a JD L belly blade a buddy has in pieces.
fallon in ct
01-11-2006 10:38:28
 Re: Belly grader for 1959 310B in reply to Farmall Don, 01-11-2006 09:18:05
Good luck! From what I gather, these things are few and far between. Should be a nice option once I figure out how it works.
