Tractor Talk Discussion Forum
Transmission oil
Harry Edwards
01-06-2006 13:02:56
If I may ask does anyone know what kind or what weight oil to put in 1952 TO-30 Ferguson Hyd system?
Thanks for any help Harry E.
geok
01-06-2006 19:04:46
 Re: Transmission oil in reply to Harry Edwards, 01-06-2006 13:02:56
If you live in north country where it stays very cold most of the time, you can get by with Hy-trans. But 80-90 GL-1 or 90 weight GL-1 mineral oil is what is supposed to be in it.
phillip d
01-06-2006 16:48:07
Hi Harry,if it was mine,i would use tdh(transmission/differential/hydraulic)oil,some companies call it tractor hydraulic fluid.best regards
bruce werner
01-08-2006 18:40:39
 Re: Transmission oil in reply to phillip d, 01-06-2006 16:48:07
Hey guy, you have gotten good answers so far, when your tractor was built, 90 weight, or 80-90 was recommended in the main, but it was very thick and hard to flow on cold days in winter. Eventually, the lighter "Tractor Hydraulic" fluid came into existance, it's now about a 10W/30 or perhaps 10W/20, but has a very strong additive pack that can do the job of protecting gears that the 90 weight did, yet act so much better for the tractors hydraulic system when cold or even in summer. Hope that helps. Chevron 1000 fluid, or Conoco Powertran fluid are excellent if you can get them, but most brands are ok.
