Tractor Talk Discussion Forum
Prospecting for a used Gooseneck Trailer
Ol Chief
01-05-2006 18:57:58
I have been looking for a used trailer.Have sighted a 28 foot beaver tail with double fold ramps.Dual tandem 16,000 lb.axles. Electric brakes.All tires appear to be in good condition though I have forgotten size and the number of plys.It is fitted w/ 2 large under slung tool or gear boxes This is a well built machine.Mfg. by Magnum in Austin, Texas.The only drawback I have noticed is the deck which is still serviceable but is a bit less than half condition.will someone hazard a guess on value as described.I have no experience with such a trailer and wonder if my 1995 F350 4 wheel non dual will handle this rig.Will appreciate all opinions.Tks.
wilson
01-07-2006 13:08:29
 Re: Prospecting for a used Gooseneck Trailer in reply to Ol Chief, 01-05-2006 18:57:58
I have a friend in az who wants to sel;l his 3 year old goose neck Its hauled only 4 loads He wants $3750.00 his phone is 928 462 4041 Ned Freestone
Brad Wright of MO
01-06-2006 13:56:58
Well it is a FORD!!! No just kidding. But if the engine is a 6.0 litre or more and your trailer can handle it. It will pull 12 big round haybales easily. when loaded corectly of course. Which is equivelant to about 24000 pounds. We pull 12 hay bales with a 91 chevy 2500 4x4 non dually and it does just fine. It has a 6.0 litre 350 in it.
Brad Wright of MO
01-06-2006 14:00:20
 Re: Prospecting for a used Gooseneck Trailer in reply to Brad Wright of MO, 01-06-2006 13:56:58
I forgot to mention that we only haul that kind of load on old gravel roads for about 6 miles at the most. I dont know how well it would handle over the road long trips or anything.
Kevin (FL)
01-06-2006 06:33:55
third party image
Ol Chief,
1st, on the value of the trailer, new trailers of that size with 10K Dexter axles would be a minimum of $5K. Used with 10K axles (oil bath tandem dual) I've seen prices as low as $2500 to $4500 depending on age/condition. Since the axles on that trailer are 16K, I would first find out the weight of that particular trailer. My guess is that it'll weigh somewhere close to 5000#'s or more. I would recommend you go with one with the 10K axles since it will likely have a lighter/smaller frame. Our trailer (shown in the photo) weighs about 5500#'s empty and the F350 SRW handles it fine. The only concern I have is when we get into off-highway mountain conditions where the grades can exceed 7-10%. The factory clutch in these trucks is not heavy enough for the 7.3 engine. Back to your trailer, I would still go with the tandem duals, but with a 20K capacity to get trailer weight down so as to allow a higher payload capacity. The SRW can handle the dual wheels with no problem--ours is also a 4x4 and this comes in handy when negotiating parking lots and tight spaces--use low range and it's like having a "creeper gear". Another good thing about have the tandem duals, you can really load up the axle position on the trailer and better control the weight on the truck's rear axle. Last Saturday we hauled my brother's JD 310 backhoe out of New Orleans--it weighs about 14K #'s. No problems with the run.
Bottom line--I would say go for a tandem dual with 10K axles and with a 28' length, you can haul two good sized tractors and it'll be easier to work in tight spots than our 36'. Weight of a 28' TD should be around 4500-5000#'s depending on frame size and other design factors. On ours, we're about to go to 5/4 treated decking to reduce weight even further.
One last suggestion and comment--get a good brake controller and if you don't already know about electric brakes, start learning. Don't know if it's just our trailer but the electric brake conponents seem to be "high need"--For just about every trip we make, I have to adjust the shoes and the magnets (~$55 each) are prone to break wires right where the wire goes into the magnet. Lately we haven't had as many problems but for the first few years, it seems like we had more than our share of brake problems. Also you'll need a 3/4" drive socket for the axle nuts. I forget the nut size but I think it's over 2".
Mike M
01-06-2006 06:43:42
 Re: Prospecting for a used Gooseneck Trailer in reply to Kevin (FL) , 01-06-2006 06:33:55
I think you better rethink about going to that 5/4 on the deck as that 14K backhoe may fall through it ! You for sure will need to add extra cross supports and that will cancel out any weight savings.
Mike M
01-06-2006 06:33:21
You didn't say what engine you have ? I think you will be better suited without the dual tandems
and just get single tandems as it will pull easier(lighter empty)and still haul enough weight for your truck to handle .
Sam in Mod
01-06-2006 04:05:31
It is a lot harder to turn a tandem dual axle trailer in a tight spot than a tandem axle with single wheels. just a thought
T_Bone
01-06-2006 02:40:06
Hi Ol'Chief,
This past summer prices:
20ft+5ft dovetail, Dexter 20k dual tandum with oil bath, forward self adjusting brakes, spring assist ramps, torque tube, all rubber mounted lites, Bulldog GN and landing gear, $5300 new.
About $160 a running foot. I probably called 15mfg in TX and they were all close on price. Very few trailers in stock and build to order about 2wk wait. Deliverly was running about $400/unit.
My thoughts, buy one trailer to last you a life time that will carry anything you want, with-in reason, for a reasonable price. You don't have to load it to maximum load weight and load it to what your tow vehicle is capable of.
Being it's a flatbed, you can load the trailer to pull great at 12% pin weight with GN hitching. That's with-in your F350 SRW spec's but a tad too heavy for GCW. Keep your GCW under 26k if you want long life out of your truck and under 20kGCW since your SRW as you don't have the control that the DRW gives you.
Dual tandums are too much trailer for any SRW tow vehicle. You'd be wasting the capicity of 4 tires.
You might consider single axle duals if your going to order a new trailer. That way you would have the side to side stability of the duals. That should drop off another $800 off the price.
The trailers are running about 150lbs to 170lbs per running foot empty weight.
T_Bone
thejdman01
01-06-2006 17:31:17
 Re: Prospecting for a used Gooseneck Trailer in reply to T_Bone, 01-06-2006 02:40:06
2 things i want to add. First watch for axle placments and what you aare hauling. I have seen axles place right back to the beavertail part of the trailer and I have seen axles in the center of the trailer, just depends what you need. I MUST say that dual jacks in front ARE A MUST. IF you ever have the need to unhook the trailer loaded the dual jackas are must better stability wise if your load isnt qute centered. Good luck Also like evryone is saying watch the brakes brakes brakes. I can PULL 15000 lbs with a 1/2 ton. (Dont laugh i bet i could get it rolling and pull it down the road. I have for work pulled 9000 w/a half ton boy was that truck sre screamin she was really really working. Was an old 305 chevy. We were going a short distance back roads and slow but still shouldnt ahve been done. The truck wil pull the load no problem, i have seen guys haul truck trailer and load 65,000 lbs of hay before. It will pull it but you will not stop it. You cant stop it. I personally have never cared if the clutch goes out motor blows up i dont like it but as long as i can get stopped ive always been happy. Also pull the trailer if the a]xles arent exacly sqare it will want to push the rear of the truck all over, and it will weable wobble
T_Bone
01-07-2006 05:00:20
 Re: Prospecting for a used Gooseneck Trailer in reply to thejdman01, 01-06-2006 17:31:17
Hi jdman,
The only problem with using 1/2ton for pulling heavy weight is they don't have a floating rear axle.
A typical 1/2ton has a pressed on axle bearing. The problem with this is if the trailer doesn't stay behind you and starts pulling side ways on the pick-up, the axle will slip off the bearing, and we all know what happens at that point.
A typical 3/4ton or 1ton has a floating axle. The wheel bearings are mounted on a stub shaft with a lock nut holding the bearing and hub on. The drive axle bolts to the hub with 8 bolts to apply torque to the wheel. In this arangement then the axle can't slip off the bearing like a 1/2ton can. This is a huge difference between a 3/4ton and 1/2ton when it comes to pulling load weight.
The same would also apply to a SRW to a DRW. Again if the trailer doesn't stay behind you then you have all that load weight pulling against two tires on a SRW but the load weight pulls against four tires on a DRW. There's alot less chance you would not blow out a tire nor would a DRW side as far on the pavement as you have more traction with the duals.
When you start getting up there in the 20kGCW plus load weights, one really has to becareful using the smaller pick-ups or that load weight will eat your lunch very fast if you make a mistake.
T_Bone
John A.
01-05-2006 20:25:10
OlChief, Magnum builds them Like no one else does. Your F-350 4x4 will handle that trailer just fine. Unless you plan to load it to the max, 24-7. then, you will need a lot bigget truck than that 1ton. More like a F-550 will be needed. But to haul a couple of tractors around to shows here and there, You should get along fine. I will venture that the I-beams in it are either 14 or 16 in Is. These trailere are about 2500 to 3500 dollars higher than the average run of trailers outthere.
Price is releative to where it is and what else is out there. Sorry I can't help you more on a price. Even when all aspect are equal the Magnums are always some higher. BUT, they will take more use and abuse then lighter trailers.
Later,
John A.
D myers
01-05-2006 19:50:57
I just listed my 1996 Kiefer 1000E Gooseneck on this site. (approx 10 min ago). It is 20' on the flat with 5' flip up beavertail, and three flip up ramps. It has two 7000lb axles with a 12000lb GVW.Pressure treated wood floor,In excellent condition, and always been housed. No disipointments! $4500.00. I pull it with a Ford F-350 Dulley, with two Farmall tractors. A Super MTA & a Super H
