Tractor Talk Discussion Forum
Re-torquing cyl.head
Diederik
12-30-2005 00:20:31
Shall i do this with cold or hot engine. Do i have to release all the bolts or one by one. which diagram i have to follow, the one for thigthening, or the one to release the head. Under the boltheads, there are no washers, is this correct??
Diederikv
12-30-2005 04:28:31
 Re: Re-torquing cyl.head in reply to Diederik, 12-30-2005 00:20:31
its a 1956 Fordson Major.
RN
12-30-2005 01:29:06
What kind of engine? Basic retightening is run engine until warm, work it a bit, then let it cool down, retighten head bolts in order of installing or start from center of head and alternate retorque bolts outward. Is this a rebuild? New head gasket on old head? note that valves will probably need lash adjusted also. Manuals for engine may have specific pattern to follow and may require warm instead of cold torque settings. RN
