Tractor Talk Discussion Forum
4020 Steering arm slop
jimjo2
12-29-2005 15:19:03
Does anyone have a fix the sop that develops on the spline between the steering arm and the knuckle on a 4020? I have a fair amount on the right side only??? I would suppose the arm is the part that is worn but I'm not sure.
Jim
jimjo2
12-30-2005 10:15:16
 Re: 4020 Steering arm slop in reply to jimjo2, 12-29-2005 15:19:03
Hey, thanks for the heads up on the A&I Tractor Parts. I never knew about them and I found out I have a store about 30 minutes form me. This forum is a great asset for guys like me.
Jim
David from Kansas
12-30-2005 06:55:42
This may sound like a shade tree/redneck fix, but it worked for me. I cut small strips of metal from a tin can to fit in each of the grooves of the splines, put the arm back on, tightened it down and it has held for more than a year now and I use the tractor and loader to move/feed large round bales and move some dirt occasionally. May be worth a try.
Mike M
12-30-2005 05:51:33
I too bought a new arm from A&I and it tightened up. If your splines are too far gone it might not tighten up. They sell new spindles too. If you don't have any money you may get by with a shim cut from a tin can then fill the voids with JB weld and use your old arm.
Jim J
12-29-2005 19:57:17
I JB welded a turning arm an our 1066 over 3000 hours ago. It is still tight. we carry a 1000 lbs of weights all of the time.
matthies
12-29-2005 17:59:22
I replaced the arm on a 4020 with a loader and a 4320 with a full rack of weights over a year ago with great success. No movement yet and they both get used heavily. chris I used the arms from A&I the aftermarket from Deere.
