Tractor Talk Discussion Forum
OT: 90 Blazer Fuel Tank
R. John Johnson
12-28-2005 12:22:44
The fuel tank on my old Blazer rotted out. Over the holidays I bought one from a wrecker. There are rust pits on the bottom where the mountin strap goes. Is there something I can do to repair that area before I put the replacement tank on? I don't want to have this tank leaking a year from now.
Thanks in advance.
John
Leland
12-28-2005 23:13:42
 Re: OT: 90 Blazer Fuel Tank in reply to R. John Johnson, 12-28-2005 12:22:44
just order a replacment plastic tank from jc whitney problem solved . Or go to LMCtruck.com they have all kinds of chevy parts .
Bryan in Iowa
12-28-2005 19:15:11
Bite the bullet and buy a NEW tank . Not worth the headaches and worries trying to patch junk !
If you must install a used tank , get a quart of "RED COAT " gas tank sealer and coat the inside of the tank .
RayP(MI)
12-28-2005 13:37:59
My old Blazer fuel tank rusted out at the rear just above the seam where the two halves were joined - too much salty road dust. I removed tank, made sure it was absolutely empty and dry - computer fan run overnight forcing air into fuel gage/fuel intake port on top, and out the fill vent. Then I went ahead and welded a patch over the offending area with a wire welder. Took several tries with to get a leak proof seal, but finally accomplished it. Kept checking for leaks, filling tank with water, until I was satisfied no leaks, then dry it out and reinstall. While you've got the tank off is an excellent time to change out the shocks, as you can get to them from below!
Bob
12-28-2005 13:04:55
How about painting the affected areas with "rust convertor"?
