Tractor Talk Discussion Forum
m444 skidloader carb questions
andrew stegman
12-26-2005 16:12:06
hello, I've got a bobcat skidloader that im working on,
it is a model 444 bobcat with the 2 cylinder onan "super" CCK i rebuilt this thing and now the carb overflows when i try to run it what i would like to know is the height spec for the float in the carb and also the starting settings for the main jet and the idle circuit screw
thanks much andrew stegman
Tom H
01-14-2006 18:55:10
 Re: m444 skidloader carb questions in reply to andrew stegman, 12-26-2005 16:12:06
Hi,
I also have a M 444 and went to my Bobcat dealer and picked up the service manual for nearly the same reason. Anyway it says to adjust the float;
with the carburator casting inverted and the float resting lightly against the needle in its seat, there should be 0.3125 inch (1/4 inch woth styrofoam float) clearance between the bowl cover gasket and the free end of the float (side opposite the needle seat.
good luck,
Tom
ps. you can email me with any other questions. I also have an orifinal M444 operator manual and parts book. the part numbers do not match the current Bobcat numbers but the diagrams are great.
Sam in Mo
12-26-2005 16:34:25
I cant help you on the bob cat. Where are you from? Work for a Co. in St Louis Mo. and was wondering if you are one of the Co's that I worked with on hwy 40.
Sam in Mo
12-26-2005 16:33:49
andrew stegman
12-26-2005 18:11:37
 Re: m444 skidloader carb questions in reply to Sam in Mo, 12-26-2005 16:33:49
st louis MO is quite a bit south of me ND is home for me
