Tractor Talk Discussion Forum
Hydraulic Coupling Tips
Christos
12-26-2005 10:50:19
Happy Holidays Everyone!
I had remotes installed on my MF 135 and how do I determine what male tips to use? Its a MF diverter valve and a MF bracket that the Female couplings mount into that rotate inside the bracket that bolts on to the back. I went to TSC today looking at tips and they had a Pioneer Catalogue and I was flipping through it and they have two different MF male tips listed. So my question for you is this - how can I tell if its a MF Female coupler and which tip do I use OR alternatively, how do I tell which Coupling system (generic, JD, IH, Case, etc...)it is so I can find the right parts?
paul
12-26-2005 23:52:47
 Re: Hydraulic Coupling Tips in reply to Christos, 12-26-2005 10:50:19
I would suggest you want the Pioneer generic type, and change out your tractor females if that is not what they are now. The units on your tractor should have a part number on them that will tell you what style they are.
--->Paul
Leland
12-27-2005 20:37:40
 Re: Hydraulic Coupling Tips in reply to paul, 12-26-2005 23:52:47
Paul the 165 I used took the same tips as the old internationals did at least what the 7 and 806 used
Leland
12-26-2005 19:06:38
Try the old style pioneer tips they should work
jhill
12-26-2005 13:09:42
The couplers shouls be marked with a brand name and a P/N. Find this and take it with you to TSC. Probably they are the ISO couplings.
old
12-26-2005 11:39:05
Some of the brands with interchange some will not. I always buy the universal type and get both ends that way I can use any of my tractors on any of my equipment just plain makes it easy and then I also know I have good working couplers.
