Tractor Talk Discussion Forum
OT A Bit , Where is the Gas Filter??
CatBlade48
12-21-2005 09:23:20
Recently purchased a New 2005 Chevy 3500 1 Ton 6 Liter Gas Flatbed. While Looking it over underneath I wondered where is the gas filter. There is none. They used to be on the frame rail under the drivers door. I have asked several people at my Dealers and have not yet recieved a good explanation for this. Now just what happens if you get some water or crud in the gas?? Anyone out there had this problem yet? Thanks CB48
Mike M
12-21-2005 10:04:14
 Re: OT A Bit , Where is the Gas Filter?? in reply to CatBlade48, 12-21-2005 09:23:20
Just looked in the GM parts catalog. No filter. You have to buy the whole fuel tank sender module,says includes lifetime filter.
My 1996 Dodge is this way and so far has no problem sucking gas thru it at 160,000 miles.
hay
12-21-2005 12:12:11
 Re: OT A Bit , Where is the Gas Filter?? in reply to Mike M, 12-21-2005 10:04:14
lifetime filter? yea, right! what happens when you get some bad gasoline that cruds up the filter? replacing the entire sender module would be expensive. i think i would have to find someone that could put an inline filter on the fuel line. at least that could be changed at reasonable cost.
Rany-S.E.-MN.
12-22-2005 05:46:59
 Re: OT A Bit , Where is the Gas Filter?? in reply to hay, 12-21-2005 12:12:11
The fact still remains that you CANNOT remove the integral filter from the Fuel Delivery Module(fuel pump). It will plug up under normal driving conditions, so adding an external filter is a waste of time...Randy...ASE Master
Butcher
12-21-2005 09:33:39
I dont know about your particuler truck but, its probably in the tank.
