Tractor Talk Discussion Forum
1947 M with live Hydraulics
Dan in Iowa
12-20-2005 14:29:38
I recently encountered having to replace the points and condenser in my tractor. I found a small amount of what looks like oil in the distributor cap and know that it is coming from the seal housing to the hydraulic pump. There is about a 3/8 inch flat tip screwdriver screw in the seal housing between the distributor and the hydraulic pump. Does anyone know what type of oil or grease goes into that housing? Sure would like some help with this.
RustyFarmall
12-21-2005 08:11:58
 Re: 1947 M with live Hydraulics in reply to Dan in Iowa, 12-20-2005 14:29:38
Take that plug out and install a grease zerk, and use whatever grease you use for the rest of the tractor. Just don't try to put too much grease in there, one or two pumps should be sufficient, or, since it has not been greased for a long time, pump slowly until you feel resistance and stop. If you have an owners manual this will be covered in the maintenance section.
Dan in Iowa
12-21-2005 14:22:43
 Re: 1947 M with live Hydraulics in reply to RustyFarmall, 12-21-2005 08:11:58
Thanks for the information.
