Tractor Talk Discussion Forum
OT truck tires
brian 1
12-19-2005 19:16:23
Going to replace the tires on my Dakota, they are size P265/70R16. Not worn out but want a better bite for my primary vehicle. My old snow truck current has standard GM wheels with LT245/75R16 tires on it. Are these sizes too far apart to mount the old 265s on the snow truck?
john17
12-20-2005 07:03:47
 Re: OT truck tires in reply to brian 1, 12-19-2005 19:16:23
You better look at the load rating on those tires before you make the switch. If your other truck has a snowplow on it, you may want the extra ply rating. Better to be safe than sorry. Just trying to point out the drawbacks. JohnG
Robert in TN
12-20-2005 00:00:16
It should not be a problem, Brian. The width is hardly noticeable. Your speedometer & odometer will be off a little though...
colekicker
12-19-2005 22:49:51
Discount Tire's website has a calculator where you put in the tire sizes and it will calculate the difference. Really something when you start figuring the revolutions a tire will make and how just a little can change a lot.
504
12-19-2005 19:49:46
brian,They will be very close in height,to check just use a tape mesure around the center of the tires to check them. kjm
brian 1
12-19-2005 19:53:54
 Re: OT truck tires in reply to 504, 12-19-2005 19:49:46
They both stand about 29 inches tall. I was worried about width of the rims but they seem to be about the same.
