Tractor Talk Discussion Forum
OT/Rust removal
Wi Craig
12-19-2005 16:06:33
I"m looking for something that will remove notable rust on steel without hurting painted surfaces. It doesn"t have to remove 100% of it, just clean it up a bit. Trans fluid? Thanks
Dan
12-20-2005 06:30:18
 Re: OT/Rust removal in reply to Wi Craig, 12-19-2005 16:06:33
White vinegar will do the trick. May have to leave it soaking for a few days depending on how deep the rust is though.
Dan
gary case
12-20-2005 06:26:22
hey ossie, can you elaborate about that elect.etc. etc.? i have a allis c that sounds like i could do that to. i just dont know what i'm talking about as far as the elect. goes. thanx gary
Ossie
12-19-2005 17:39:02
depends on how big an object you want the rust off of and the paint to say on ?? Electrolic derusting is easy and free. If the Item is small enought to fit into say a 55 gal barrel I would use this method. It works for me.
Best Regards
Ossie
Ospho
12-19-2005 16:46:05
I think the stuff is called Ospho... ask for it at Ace hardware. It's phosphiric acid and it's about 10 bucks per gallon... (or maybe $25) I forget, but it will go along way...
hth
Ospho
