Tractor Talk Discussion Forum
Generator Disassembly
Aaron Ford
12-18-2005 16:10:47
The neighbor is trying to convince me that a vintage Massey needs a generator to look proper. I disagree on grounds of functionality, (or disfunctionality), cause an alternator beats a generator hands down. But then there is the tachometer issue to deal with. So I began taking it apart (cause it don't work) and found a broken brush spring and some worn out bearings. My question is this: how do you remove the tach drive gear from the end of the shaft so that the outboard bearing can be renewed? Thanks in advance, Aaron
Logan in SE Tex.
12-19-2005 00:03:24
 Re: Generator Disassembly in reply to Aaron Ford, 12-18-2005 16:10:47
Aaron, I think you would do good to post this down on the Massey-Harris/Fergusson board. A fellow named Big Dean down there is the resident expert, he helps all comers. Sorry that is all I have to offer. Good Luck
Aaron Ford
12-19-2005 07:32:27
 Re: Generator Disassembly in reply to Logan in SE Tex., 12-19-2005 00:03:24
I did, he did, I am now firmly squared away... But thanks anyway.
