Tractor Talk Discussion Forum
How replace fan belt Case 580B
old
12-16-2005 12:04:53
Friend has a 580B case back hoe and he broke the fan belt. Went to look at it but not sure how to get to the hyd pump to pull it forward to be able to replace the fan belt. Any body know how to do this and what might neeed to be removed to do so?? Thanks
Johnski
12-17-2005 06:39:31
 Re: How replace fan belt Case 580B in reply to old, 12-16-2005 12:04:53
Old, I found this site a while back but I haven"t ordered from them yet. These belts can really be a help. I remember Dad having them on several pieces of equipt. HTH jf
Johnski
12-17-2005 06:41:45
 Re: How replace fan belt Case 580B in reply to Johnski, 12-17-2005 06:39:31
I guess I'm not bright enough to add a link so you'll have to copy it :>(
http://www.fennerdrives.com/nutlink_and_supertlink_vbelts/nut_supt_home.asp
mf294-4
12-16-2005 21:06:23
Had to replace one on our 580b, not an easy project. The coupler would not slide on the shaft so had to loosen the bolts that hold the pump and pull it out. Would be much quicker and easy if coupler is not stuck.
Mabrey
12-16-2005 15:34:59
If it's like some of the others, unbolt the pump drive coupler and slide one, or both halves apart and up on to it's, or their shaft(s).
It leaves just barely enough room to squeeze a belt through there.
