Tractor Talk Discussion Forum
planning cyl. heads
Brandon Snodgra
12-15-2005 19:50:06
I am think about planning my head on a 1950 'M Farmall. i was told all i should plan is 10 to 12 thousands. what do you all think
thanks brandon
Bob
12-15-2005 20:37:09
 Re: planning cyl. heads in reply to Brandon Snodgrass, 12-15-2005 19:50:06
.010" or .012" sure isn't much! Are you trying for more power, or to correct a pitted or warped head?
Brandon Snodgrass
12-16-2005 07:02:00
 Re: planning cyl. heads in reply to Bob, 12-15-2005 20:37:09
Im trying for more power
RN
12-16-2005 16:05:56
 Re: planning cyl. heads in reply to Brandon Snodgrass, 12-16-2005 07:02:00
More power? Check pulling board for Chad S- he had some IHC hopup tips that included milling heads about .040/1mm or more depending on pistons. You were given normal machine shop recommendation for flatenning head to take care of pits and minor warping for good sealing- this is good advice for working use and long life. Hotrodding is different, engine life expectancy is not a prime concern. RN
