Tractor Talk Discussion Forum
Stuck Engine Juice
in-too-deep
12-15-2005 19:05:25
After reading many threads about un-sticking engines, I've found that one person could never decide which substance to use if their engine is stuck. I've heard ATF, brake fluid, diesel, Liquid Wrench, PB Blaster, Kroil, Mystery Oil, even Coca-Cola. The list grows ever larger. Maybe we should have a laboratory do a test on which actually works the best. I bet they couldnt come up with a solid answer, either.
Mike S 806/H
12-17-2005 05:35:39
 Re: Stuck Engine Juice in reply to in-too-deep, 12-15-2005 19:05:25
Olive Oil!
old
12-15-2005 20:20:51
Over the many years that I have worked on engine and tried all of that stuff theres 2 that have worked better for me. These 2 are tranny fluid and turpentine, on there own or mixed depending on differant things. I've done the oil, diesel, PB and most of the others and how found the 2 I talked about to work best, hands down.
Leland
12-16-2005 20:08:38
 Re: Stuck Engine Juice in reply to old, 12-15-2005 20:20:51
I perfer brake fluid and 2 stroke motor oil mixed 50-50 has unstuck a lot of different thing for me .
old
12-16-2005 20:20:35
 Re: Stuck Engine Juice in reply to Leland, 12-16-2005 20:08:38
But have you ever tried the tranny fluid and turpentine?? I've done the brake fluid thing and even tried oil with it and found tranny fluid to work faster and better.
Leland
12-17-2005 01:23:31
 Re: Stuck Engine Juice in reply to old, 12-16-2005 20:20:35
Never used it for that but I have dumped many a quart down the carb of a running moter to clean up sticking valves
old
12-17-2005 07:06:07
 Re: Stuck Engine Juice in reply to Leland, 12-17-2005 01:23:31
I'd bet you would find the tranny fluid will work better the the brake fluid.
Leland
12-17-2005 10:51:53
 Re: Stuck Engine Juice in reply to old, 12-17-2005 07:06:07
I always just used the brake juice bacause it always just melted rust but will give ATF a shot .
old
12-17-2005 11:47:42
 Re: Stuck Engine Juice in reply to Leland, 12-17-2005 10:51:53
Well if you think brake fluid melts it you should try turpentine it melts rust like brake fluid but faster also.
