Tractor Talk Discussion Forum
Tire repair?
Del MI
12-15-2005 17:29:10
While pushing snow today with the tractor. I backed over a 3/4inch peace of rebar and punctured
the rear tire. A pie shaped hole about the size of my thumb between the cleats. Tire shop said can't fix. New 11.2x24 $149.00 + tube. Tire had less than 190 hours run time on it. Anyone have any ideas for a farm fix on this? Thanks.
Nebraska Cowman
12-16-2005 04:11:58
 Re: Tire repair? in reply to Del MI, 12-15-2005 17:29:10
can't fix it, or won't fix it? I'd call around and find another tire shop.
TGIN
12-16-2005 02:02:57
Ran over a broken T-post with rear tire on backhoe . Tire was about half , they put a big boot on the inside and it lasted 4-5 yrs. and it did`nt get pampered .
Leland
12-15-2005 19:54:50
Look for a large patch plug this is like a boot and plug all in one should fix the problem
fixerupper
12-15-2005 18:20:56
Gemplers sells a rubber putty kit. It might seal the tire from the outside, along with using the boot on the inside. Anyone out there tried the stuff? It"s $49.50 per kit in the latest catalog P 523. Jim
cannonball
12-16-2005 04:30:33
 Re: Tire repair? in reply to fixerupper, 12-15-2005 18:20:56
they also have a plug with a seal on the inside..they are up to one inch in dia..check them out they fill up hole and seal ...have nice day may god bless
RodInNS
12-15-2005 18:03:00
Is it that the tire shop can't patch the tire, or that it isn't really worth patching? I was quoted a price of about a hundred bucks just for the blowout patch, plus labor for a flat I had about a year ago. Granted, that was a bigger hole than you describe. So in my case with a tire that had 25% tread left, it really wasn't worth fixing. Yours, at 150 bucks new, is sort of a coin toss, because if the first patch doesn't stick, then you're into the cost of a new tire. That's a very good price you were quoted as well, as I priced several 12.4x24's yesterday that ranged from 275 for a 4 ply bias to 640 for a 1* radial. Those are priced in Canadian dollars. Think I'd just get the new tire and be done of it. FWIW,
Rod
phil in ns
12-15-2005 18:41:06
 Re: Tire repair? in reply to RodInNS, 12-15-2005 18:03:00
Rod...FYI Central tire in Noal has cheapest tires I found yet ,they also load em cheaper then anyone in metro ...I know your far away ,but noals only 45 minutes from truro if your down this way...
THey also sell ice chains $30 cheaper then Nova
oleblu
12-15-2005 18:02:03
Take it to a recap shop. They will do a section repair by cooking in new rubber and reenforcing it with a boot. Thats the proper way. If you just put a boot on the inside moisture will be able to get to the cords and you will eventually have other problems. A section repair should cost about $40 if you bypass the tire store to send it in for you. Remember that everyone that handles that tire wants a "piece of the pie".
Mike M
12-15-2005 17:47:18
I have seen section repairs done. This vulcanizes in a new piece of rubber. I think they do them at the same shops that do retreading. That is not that big and a boot would be worth a try for the do it yourselfer.
old
12-15-2005 17:40:14
Put a boot over the hole. A boot is just a big patch, they come in a lot of sizes. I have done that to a number of tires that where to good to throw away but had a hole in them. Then if you really want to do it right put a liner in too.
edchainsaw
12-15-2005 18:28:01
 Re: Tire repair? in reply to old, 12-15-2005 17:40:14
We had a WILLING tire dealer when we did that exact same thing.. to the same size tire I might add
we booted it. tube in the tire for sure.. and put silicone glue in the hole... that was 6 yrs ago its still working... ( it was our backhoe loader's tire so it gets spun some)
Del MI
12-16-2005 17:09:50
 Re: Tire repair? in reply to edchainsaw, 12-15-2005 18:28:01
Thanks for all the responds. I bought the new tire but I kept the old one to fix later. I did not know about section repairs used on recapped tires.I always thought the tire carcass had to be in perfect shape to be used for a recap. I will look for a local recapper to see about fixing it. If not It will get a boot put in it. Its like every thing else. No one wants or can't fix anything just wants to sell new. The tire place I took it to was not your chain type car and mini van tire store. Its a place that deals with trucks and off road equip. And has field service trucks. I was expecting if it could be fixed they were the most likely ones to do it.
Thanks again.
