Tractor Talk Discussion Forum
Not to sound like a tightwad but....
Jeff63
12-15-2005 12:43:10
The ac clutch locked up on my 99 f-250 5.4L gas motor pickup. I'm buying lumber and steel trusses ect. to build a pole barn and don't want to spend 3 or 4 hundred on a new clutch and compressor (I think comp. may be shot as well) till spring if I can help it. Wonder if I can buy a non air belt and get by for a while, will routing be the same as ac equipped truck with exception of compressor?
dp innd
12-15-2005 19:50:48
 Re: Not to sound like a tightwad but.... in reply to Jeff63, 12-15-2005 12:43:10
get a new clutch bearing for $20,the pump may be good,its not that hard to put in.
ross in ns
12-15-2005 15:41:33
not to sure about fords but the gm and dodges i have had a little picture on the top of the grill for routing belts with ac and without
Redmud
12-15-2005 15:36:26
Clutch bearings are not hard to replace.
RCP
12-15-2005 15:04:05
 One for sale in PA in reply to Jeff63, 12-15-2005 12:43:10
My brother in law has his 99 for sale, sounds like a twin to the one you are looking at, but his is cheaper. Interested?
doogdoog
12-15-2005 14:32:11
Aloha, I would agree that a used compressor would get you going until it is fixed permanently. If you can't get one, you could probably make an idler pulley. As far as the non air belt, you would probably have to see how the original belt is routed to see if it would work. The non air belt may be shorter or it may be the same length as the air belt because of an idler pulley in place of the compressor.
Mahalo,
doogdoog
Lumpy
12-15-2005 14:20:41
How are you driving it now? Personally, I'd fix it because of the defroster working 10 times better. But you could got to the local auto parts store and try the non ac belt and see if it works.
Nebraska Cowman
12-15-2005 13:59:42
What I did once was put on a non-working compresser that still had a good bearing. I think I gave about $25 at the junkyard
37 chief
12-15-2005 13:54:56
When I buy a new belt I am always asked does it have air. Maybe you could just take the compressor out and buy the belt for a non air setup. Stan
SMA in NE
12-15-2005 12:58:55
You should be able to disable the clutch for the AC unit by disconnecting the wire lead to it. This will allow the pulley to turn but the AC compressor will not run. Keep in mind your defrost system will not work as well with your AC not working.
Jeff63
12-15-2005 13:09:06
 Re: Not to sound like a tightwad but.... in reply to SMA in NE, 12-15-2005 12:58:55
Clutch bearing is locked up
