Tractor Talk Discussion Forum
ford ranger
baler 46
12-11-2005 21:27:32
Just wondering if there is a fuse some where for the 4+4 if it does not work .The light comes on but the front axels do not work .year is 93 with push button 4+4 thanks
idontno
12-13-2005 07:17:17
 Re: ford ranger in reply to baler 46, 12-11-2005 21:27:32
It"s proubly your shift motor on the tranfer case.Mine needs one about every 2 yrs.They get dirty and rusty and won"t shift.It"s a easy fix.Unplug it and pull it off.Take the end off and look in it.You will see the problem if that is what it is.Sometimes you can clean it and it will run ,but most of the time it will needed replaced.$125.00 at Autozone.Go to www.rangerpowersports.com.Do a search on shift motors.They discuss this a lot.If this isn"t the problem then you will have to look deeper.But check the shift motor first.Usually the problem...Good luck... idontno
bradk
12-14-2005 09:43:14
 Re: ford ranger in reply to idontno, 12-13-2005 07:17:17
idontno; Not trying to be a smart-alec,but the original post says the 4WD light comes on.If the t-case motor was innop.,this wouldn't be the case...regards~brad
bradk
12-12-2005 17:47:07
bob g ny is right.One of your front hubs are broken on the inside.I know they say it's "shift on the fly",but they break hubs.If you shift into 4WD w/vehicle stopped,you can eliminate the problem.~brad
Pete in Cal
12-12-2005 07:31:06
Could be the shift motor is bound up. I had the same prblem on a '91 Bronco. Easy fix, email for more info. Pete
bob g ny
12-12-2005 05:05:21
one of your front hubs are broken. in those years ford used a plastic part that there are three little plastic teeth on. They break and the axle wont engage.
1967jd
12-11-2005 23:49:33
check under the hood in the fuse block there should be one
