Tractor Talk Discussion Forum
International Harvester 706 Farmall
Joe Lizotte
12-11-2005 16:14:07
I can not get power steering to work. There is no hydraulic power at vaulve body. Have check the manuals and can figure it out. Any suggestions?
the tractor vet
12-11-2005 20:13:15
 Re: International Harvester 706 Farmall in reply to Joe Lizotte, 12-11-2005 16:14:07
Have you changed the hdy. filter ?? Does your PTO work???? does the 3 pt. work ??? and do live where it is cold ???? need to know this first.
Joe Lizotte
12-12-2005 10:47:07
 Re: International Harvester 706 Farmall in reply to the tractor vet, 12-11-2005 20:13:15
Changed the hdy filter and hydrolic oil.The pto does not work nor the 3 pt.Checked valve body everything looked good.Changed o rings. There are two pumps.Can one work without the other? Can you check pumps without taking them out? Nothing hydrolic works.Would appreciate any input.
J.Lizotte
12-12-2005 15:37:29
 Re: International Harvester 706 Farmall in reply to Joe Lizotte, 12-12-2005 10:47:07
Thanks for the input. Will try it and let you know if it works. THANKS
the tractor vet
12-12-2005 13:49:51
OOOOO kkkkk HUSTON WE HAVE A PROBLEM , Time to split the tractor at the bellhousing she done and went and ate the splines off the PTO input shaft and also the pressure plate . SO now you need a PTO input , one PTO input bearing a couple seals and O/Ring a clutch and pressure plate and also GRIND the flywheel and step .
J.Lizotte
12-14-2005 12:35:52
 Re: International Harvester 706 Farmall in reply to the tractor vet, 12-12-2005 13:49:51
How much do you think the parts will run about? Thanks for the input any suggestions will be appreciated. Thanks
J.Lizotte
12-12-2005 18:17:44
In reference to the parts you said I needed what would be the parts cost?
