Tractor Talk Discussion Forum
weight of hoe ??
mhunt
12-10-2005 20:05:17
I just bought a 580B construction king case backhoe and am having some fun trying to find the exact weight of this machine to haul it and any good source for specs of same. If anyone can help me out, it would sure be appreciated. Thanks in advance for your time.
ANGUS BOB
12-12-2005 02:54:55
 Re: weight of hoe ?? in reply to mhunt, 12-10-2005 20:05:17
I HAVE A 580C,SAME AS B JUST A LITTLE NEWER.MY BOOK SAYS 114OO.IF YOU HAVE AN ENCLOSED CAB OR EXTEND A HOE YOU WOULD HAVE TO ADD SOME.
Paul in Mich
12-11-2005 06:29:35
Its hard to get an exact weight unless you scale the rig. The manufacturers weight may not reflect a lot of weight added later. It may have loaded tires, beefed up areas etc. Can you run it across a scale somewhere in your area? If so, that would be the most accurate way to determine the weight.
BobHnwOh
12-11-2005 05:24:09
12,000 to 13,000.
Larry NE IL
12-10-2005 21:22:54
I don't know exactly, but it should be about 16,000 lbs. Isn't there a Case dealer near that You can call? They should have all the specs. Larry NE IL
