Tractor Talk Discussion Forum
11.5hp wiring diagram needed
chris sweetland
12-09-2005 08:08:18
i am looking for a wiring diagram to an 11.5hp briggs model 259707 type 4026-01 thanks
chris sweetland
12-09-2005 09:20:56
 Re: 11.5hp wiring diagram needed in reply to chris sweetland, 12-09-2005 08:08:18
ok the wires burned up i guess i should have told the story i can make a wireing harness no problem its just when the wires burned (small fire leaky gas tank wish i knew but it cought the insulation on fire) and now it dosent have spark anymore if you can get me to get spark i can manage the rest
JT
12-09-2005 13:33:46
 Re: 11.5hp wiring diagram needed in reply to chris sweetland, 12-09-2005 09:20:56
Unhook the wire at the coil that kills it, if that don't help, you probably have a bad coil wire and need a new coil
JT
12-09-2005 08:33:07
There is no "wiring diagram" for Briggs engines other than what is in repair manual. Most wiring diagrams are part of the tractor parts/service manuals and they can be reeaallll fun to get. We had an MTD 2 weeks ago that I neded one for, MTD said "don't exist" How do you fix it with that attitude from the manufacturer??? But it is MTD we are talking about.
buickanddeere
12-09-2005 08:30:04
It's likely just two AC lines coming off the stator and running to a rectifier or rectifier/voltage regulator. Sometimes two pairs of leads are ran out from the stator. Two AC wires to lights and two AC wires to the DC recitifier/regulator charging system. Magneto or coil ignition? Magneto shorts out to stop the engine. The coil ignition opens the circuit. Most of these can be wired up just using some measurements with a muiltimeter and some investigation. If a rectifier/regulator cannot be found. Just a bridge rectifier and a zenor diode from Radio Shack does the same.
JT
12-09-2005 08:45:19
 Re: 11.5hp wiring diagram needed in reply to buickanddeere, 12-09-2005 08:30:04
All Briggs engines are magneto type igntion and these smaller ones(single cyliner) normally do not have a regualtor/rectifier. The either one lead for DC only or 2 leads one for AC one for DC coming out under flywheel. The DC has a diode in it.
