Tractor Talk Discussion Forum
John Deere LUC power unit
Tom R
12-08-2005 02:30:08
Does anyone out there know the year(s) that John Deere used a coil/distributer on the LUC vs the mag?
Although I don't have it in hand, I'm sure I have a coil unit.
Don Reavis
12-08-2005 13:00:52
 Re: John Deere LUC power unit in reply to Tom R, 12-08-2005 02:30:08
i have a brand new mag for the LCU if ya need it .. Its the same as the JD L and LA
Tom R
12-08-2005 06:11:27
This is a 2cyl unit, I don"t think with elect.
start originally. But appears to be coil&distributer factory part.
Mike M
12-08-2005 11:48:29
 Re: John Deere LUC power unit in reply to Tom R, 12-08-2005 06:11:27
Do you have any names or numbers off of it ? They did use at least 3 different types of Magnetos that I have seen so far. The Wico type C has an external coil wire this may be what you are thinking of ? Someone could of also added an external coil and just use the points to fire it ?
Mike M
12-08-2005 04:18:10
I don"t think they ever did. Is yours a 2cyl. or a 4 cyl. unit. The 4 cyl. units (HA92)used on the 25 combine did use a battery ign. I think ?
DCM
12-08-2005 05:57:03
 Re: John Deere LUC power unit in reply to Mike M, 12-08-2005 04:18:10
The 2 cyl LUC I have is mag fired. Dan
