Tractor Talk Discussion Forum
How To Retrieve Your New Tractor
Not Me
12-07-2005 17:37:58
I agreed to buy the tractor. That was the beginning. The problem was the tractor was not running, and 250 miles away. Enter U-Haul. Rented their 77 inch wide trailer for 24 hours at $49.99. Trailer was supposed to be good for 4000lbs. MF says tractor weighs 4019 dry. Oughta work. Tractor could be 60 in wide or 84 depending on wheel set. Recall trailer was 77 inches. Might work. Brought tools. 5 hours later I arrive at pickup point to load tractor I have never seen.
Good news: Tractor is in better condition than expected. Wheels are at 1/2 spread ~76 inches.
Tractor is oriented downhill.
Sellers sons have arrived to help.
500lbs of wheel weights
Bad News:
It is 10 degrees.
It is dark.
Tractor is froze to ground.
Clutch is froze to pressure plate.
500 lbs of wheel weights won't come off. Did I mention it was 10 degrees?
Okay, so the tractor broke loose from the ground bringing large amounts of sod with it. It was moving. 30 minutes later, tractor was firmly chained to trailer. Owner was paid, directions given, and we were off. I found that it is impossible to unload a tractor on your driveway at 3AM without waking your wife and kids (neighbors too, but they don't matter). Only after getting it home did I find that the tires were loaded with Calcium. You can do your own figures, but with a 28x14.9 inch tire, the weight should come in around 1000lbs for two tires. This leaves the final weight on the 4000lb max trailer at 5500 lbs not including lubricants and a tank of bad gas. I should mention that while trailering rusted farm machinery, do not be surprised when it becomes the focal point of every gas stop, pit stop, and Cracker Barrel parking lot. I got more connections, advise, and comments (congratulatory and otherwise) than I ever expected. I will mention that currently the tractor is running, driving, and has supplanted the wifes Walmart cruiser in the garage. Kinda hard to move when I have the axle off. I swear this wasn't planned. Hee Hee ;-)
Bruce in KS
12-08-2005 16:19:51
 Re: How To Retrieve Your New Tractor in reply to Not Me, 12-07-2005 17:37:58
Bought my big Oliver at a sale this summer and finally found someone there to haul it the 55 miles back home. Had talked to more than a dozen ppl at the sale getting prices from 70 to 200 bucks (timesframes of 2 hours to 2 weeks). The 70 guy backed out, so I took the first $200 guy. Then he backed out, so I found another $200 guy. He had a kid show up in an f350 with a gooseneck and off we went. Got the tractor unloaded, whipped out the bills, and confirmed the $200 bill. Well, the kid said it was $110 as the 2 I had discussed with the middleman was $2 a mile not $200. Paid the $110 bill and gave the kid one of my extra twenties so he didn"t feel to bad, plus he drove slow like I asked him to.
L.C.Grey
12-08-2005 07:43:49
Quote from Not Me: "I should mention that while trailering rusted farm machinery, do not be surprised when it becomes the focal point of every gas stop, pit stop, and Cracker Barrel parking lot. I got more connections, advise, and comments (congratulatory and otherwise) than I ever expected."
I know just what you mean. When I went to Iowa a couple of years ago to retrieve a 1929 Mc Deering 22-36, all the truckers kept my CB abuzz all the way back to Texas talking about my newfound prize.
I got approached everywhere I stopped for food or fuel all the way home. Unfortunately none of 'em offered to buy me lunch, fuel or follow me on home to help unload. But it was a great road trip anyway.
John (MO)
12-08-2005 05:54:04
Good luck, there seem to be several new farmers a a day with even less experience and common sense than you have.
cj3b_jeep
12-08-2005 05:30:01
We hauled my DB 880e home 12 miles on my buddy's home made 1972 Ford rollback. He's had over 5000 pounds of rocks on this thing before and said the tractor was the heaviest thing he's ever hauled, you could see the dualies on the truck complaining. It was either the roll back or driving the tractor home, which I was not keen to do being unfamilliar with it.
John No Mi
12-08-2005 05:09:43
I have bought a tractor that is 518 miles from where I live. My trailer that I built to haul a MM BF (4820 pounds with wheel weights and cloride) is maybe not strong enough to haul the MM 335 with loader and is for sure not long enough. I have made arrangements to borrow a friends trailer he hauls a JCB backhoe on. Now I just need three days that are not heavy snow fall. A daughter lives 1/2 way there so I can stop there overnight on the way. That way I will arrive early enough to load the tractor in daylight. Get loaded and start for home with plans to stop at a motel when part way home. Just have to watch the weather reports and pick the right day to start.
Jon Holt
12-07-2005 20:24:16
I have to go to se missouri from ne kansas this weekend and pick up a tractor. I hope my luck is good. I have already had to weld a spring perch on the trailer, replace all of the bushings, rewire the brakes and put a radiator in my sub as which we had 6 inches of snow coming down and I had to do it outside as I had a customers car in side that just had to be fixed now.
old
12-07-2005 20:33:50
 Re: How To Retrieve Your New Tractor in reply to Jon Holt, 12-07-2005 20:24:16
Sounds like your going to be in my neck of the wood this weekend. To bad its not one of my tractors leaveing with you, I need the room in my sheds
Dixieland
12-07-2005 20:05:44
That's why I don't buy any tractors north of Nashville this time of year. I have, but it only took one trip to Nebraska in March a few years back. The dadgum streams there (Kearney) were frozen along with my son-in-law. That was a long, cold, expensive trip. Glad to be going South on the return.
960
12-07-2005 20:00:59
Excellent narative on what makes this hobby, addiction, the great activity it is for remaining sane in an insane world or is it becoming insane with the rest of the world or now I'm confused. Happy collecting.
Jerry/MT
12-07-2005 18:53:36
Somebody once told me "it's better to be lucky, than good"! Glad it all worked out for you.
Allan in NE
12-07-2005 18:24:28
Wait just a darned minute!!
Are you trying to say that you didn't have to go purchase another pickup, pay to get a hitch installed and are you also saying that you didn't have to then go buy a flatbed trailer to go fetch your tractor?
Is that what you are saying?
Boy! Am I ever a bonehead! :>(
Allan
BobinKY
12-08-2005 12:03:19
 Re: How To Retrieve Your New Tractor in reply to Allan in NE, 12-07-2005 18:24:28
Hope my wife don't see this!!!
wayne2
12-07-2005 17:53:20
GOOD MAN!!! Ignorance is bliss. Few minutes in trk even cold dosen't hurt Hugh!!! W
in-too-deep
12-07-2005 17:53:14
Jeez, I got off easy. Borrowed my ag teachers truck and trailer. Thought I'd pull the derelict JD B on with a come-a-long and chain. Haha. Guy comes along with the boom tractor, he nudges it from behind to push it on the trailer. Rear weels are locked up, and no rubber to speak of. As he's pushing the tractor I'm afraid the transmission is going to break. I get in on the trailer, and chain it down. Only a few miles to home. I end up yanking the tractor off the trailer with the CASE 400. Now I can start figuring out what i got myself into...
Kent in NB
12-07-2005 17:48:42
Grin ,and bear it.
Harley
12-07-2005 19:08:28
 Re: How To Retrieve Your New Tractor in reply to Kent in NB, 12-07-2005 17:48:42
Ah yes, and now you're just beginning to see what us old forts have been putting up with all along. Wait till you have about $4500.00 in that $900.00 tractor and the little missus first starts to realize that. Then you tell her the only way you can recoup all that gingle is to sell if for half what you have in it and go buy another one. Well it worked for awhile here till she said I had to start buying, fixing, selling, in that order and not taking forever doing it. It was a good run for two years till diesel went out of sight. Luckily I didn't have any sitting around when I bailed. Happy tractoring, Harley
