Tractor Talk Discussion Forum
frozen trans on to-20
chris sweetland
12-07-2005 09:56:02
my to-20 is frozen solid due to water in the rear end how do i un freeze it/drain and fill it and what do i fill it with
Duner Wi
12-07-2005 17:26:04
 Re: frozen trans on to-20 in reply to chris sweetland, 12-07-2005 09:56:02
Fill it with GL 1 90 Wt. Napa #65 205 I think is the #.
Jerry Cent Mi.
12-07-2005 12:58:53
If you are outside and can't move it you can probable thaw it with a charcoal fire under it then move it inside and drain it.
RAB
12-07-2005 12:35:27
Warm gently until ice melts (@ zero degrees Celsius). Then loosen plug(s) to drain off water and top up with OIL, or remove drain plug(s) and drain all fluid before replacing plug(s) and refilling with OIL.
On no account should you refill with water and/or antifreeze.
Your post probably spawned the one two up from yours!
old
12-07-2005 10:42:11
If its due to frozen water then one way would be to get a couple gallions of alcohol and pour that in. The alcohol will absorb the water and then you can drain the rear end. Then just refill with the right type of fluid. I've had that happen with fuel systems and doing the alcohol trick fixed the problem in less the 2 hours.
