Tractor Talk Discussion Forum
O.T. How to get yellow off vinyl windows
Gene or Georgia
12-06-2005 16:24:31
I recently bought a golf cart with the idea using it at shows for transportation maybe,and one of the vinyl windows in the wet weather cover has turned yellow. It would be o.k. to use like tinted window maybe except that it is half yellow down one side of the windshield part and the other half that apparently was not exposed is still fairly clear. Can this be removed, or is it necessary to pitch the vinyl and try to replace it? Thanks for any advice. gene Davis
John *.?-!.* cub owner
12-07-2005 06:17:29
 Re: O.T. How to get yellow off vinyl windows in reply to Gene or Georgia Ann Davis, 12-06-2005 16:24:31
Go to your locla autozone or o'rieelys and get some Plexiglass cleaner, it will help sometimes. Second suggestion, is if it's just one of the all weather covers that drops over the entire cart with aip up doors they can be bought at many golf cart places and on Ebay for around $100. due a searc for golf cart cover.
Mike M
12-07-2005 04:54:27
Company Jeep at work has a soft top that the windows turn yellow. They have used a good car cleaner/wax on them seemed to help.I did the same to a plastic gauge cover on a Ford backhoe and it helped enough I can now see the gauges.
Gene Davis (Ga.)
12-07-2005 03:47:14
Thanks All, Will just se about replacing it. Gene
1967jd
12-06-2005 20:46:38
Actually the its not really a stain, its the fading of the pigments that are not light stable. Worked in plastics for 25 plus.
Might as well just go to a tarp shop and make new ones
wayne2
12-06-2005 17:30:26
Go to boat canvas-boat tops etc, they have the vinyl in rolls and the power machines to sew it. shop around,things like zippers,attaching hardware and other incidentials drive up cost!! W
doogdoog
12-06-2005 17:13:37
Aloha, All the one's that I have come across was a lost cause and the oil in the vinyl is probably gone too, like when a vinyl dashboard cracks with age from being exposed to the sun.
Mahalo,
doogdoog
shannon from ohio
12-06-2005 16:38:23
Might try white vinegar and see if it works,But most plastics that get stained or yellowed usually needs replaced because the stain will permeate (absorb) into the plastic....
