Tractor Talk Discussion Forum
4 cylinder oliver tractor-what year???
arn
12-03-2005 00:21:22
we have a 4-cylinder oliver with ser#20693-606. Can't find this serial #. Can anyone help identify the year? Thanks
oliver fan
12-03-2005 07:45:11
 Re: 4 cylinder oliver tractor-what year??? in reply to arn, 12-03-2005 00:21:22
You need to look at the serial number plate again. You do not have enough numbers. Look close and see if you are missing a number 4 at the start.
arn
12-05-2005 00:50:05
 Re: 4 cylinder oliver tractor-what year??? in reply to oliver fan, 12-03-2005 07:45:11
That is what we thought but there is no physical sign there is any other number missing. I even used a magnifying glass on the plate and it is in good shape.
oliver fan
12-05-2005 16:28:06
 Re: 4 cylinder oliver tractor-what year??? in reply to arn, 12-05-2005 00:50:05
With the number and/or missing numbers you probably have a 66 fleetline tractor built in 1950 or 51.
The Oliver 60 would fit the discription that you gave if the first number (missing) was a 6.
However the clue is the 606 spec. number that I think would make it a 66.
arn
12-07-2005 01:06:34
 Re: 4 cylinder oliver tractor-what year??? in reply to oliver fan, 12-05-2005 16:28:06
Arn seems to think this tractor is from 1935?
You seem to know a alot so might I ask you: He drained fluid and full of water. Wants to replace but doesn't know formula that should be used or where to replace. Is there a basic manual that can help him? thanks
