Tractor Talk Discussion Forum
AC -D14
woodsplitter
12-02-2005 15:43:40
Why does my Allis Chalmers D-14 keep slipping out of gear?
Appreciate any help.
Hurst
12-02-2005 18:32:21
 Re: AC -D14 in reply to woodsplitter, 12-02-2005 15:43:40
First thing to check is the shifting fork adjustment. Let me guess, it is most likely 3rd gear? If not third, then normally 2nd is the next most common, and if not second, then 4th is the next most common. It could be as simple as adjusting the fork or replacing it, or it may be as complecated as breaking down the whole tranny, replacing the gear, collor, fork. I hope it is the fork at worst. check out this address to a discussion about a D15 that started slipping out of 3rd and second:>Link
Hurst
woodsplitter
12-03-2005 21:24:22
 Re: AC -D14 in reply to Hurst, 12-02-2005 18:32:21
I"ll check that out.
Thanks alot.
nhboyd
12-02-2005 17:13:54
a shifting fork is worn and not shifting collar far enough to lock on to gear. the collar may also be worn so under a load is slips off.
woodsplitter
12-03-2005 21:26:20
 Re: AC -D14 in reply to nhboyd, 12-02-2005 17:13:54
will check it out. thanks for your help.
