Tractor Talk Discussion Forum
91 Honda Accord
tlak
11-28-2005 02:02:06
My daughter"s car will go into fast idle every once in a while. Last time it happened she said she was setting at idle and it just ran up to 2500 rpm. Any ideas?
Martini
11-28-2005 13:32:24
 Re: 91 Honda Accord in reply to tlak, 11-28-2005 02:02:06
Does it have a throttle positioning sensor?
Good place to start.
tlak
11-28-2005 15:01:00
 Re: 91 Honda Accord in reply to Martini, 11-28-2005 13:32:24
Haveta check
Tom in TN
11-28-2005 09:58:18
tlak,
I've never owned a Honda, so you can tell that my advice isn't worth much. However, I do know that surging engine speed is often caused by a vacuum leak. Often, a cracked hose will open and close intermittently causing the engine speed to vary up and down. I'm not sure if a vacuum leak would cause an engine to surge up to 2500 RPM, but that's stil the first thing I'd look for.
Good luck,
Tom in TN
