Tractor Talk Discussion Forum
Char-Lynn Power Steering Leak HELP!!!
MCL
11-25-2005 15:13:00
I am trying to put an aftermarket Char-Lynn power steering unit on a 770 Oliver. The seal on the pump shaft behind the pulley leaks. I was going to take it out and try to find a match at NAPA. Anybody out there worked on these and know of a better parts source or any secrets to taking it apart?
ILL John
11-25-2005 17:19:43
 Re: Char-Lynn Power Steering Leak HELP!!! in reply to MCL, 11-25-2005 15:13:00
I've got a Char-Lynn unit on a MM, just ran the main hyd power from the tractor pump to, then from , the unit back to the origional destination, never had any trouble, also use automatic transmission oil in it. Seems to me that the C/L pump resembled the older GM p/s pumps, you may be able to get a kit or rebuilt.
