Tractor Talk Discussion Forum
Help! Need to rework logging slash piles
Richard Scott
11-25-2005 15:04:30
We logged about 5 acres a year ago and the logger piled the slash with an excavator. The slash is mostly long limbs with few logs. It was too late in the year to burn the piles before the winter rains hit here in western Oregon. So last summer, I covered the 42 piles with plastic. First mistake was to use plastic that was too thin.
The piles were packed very tight and there were lots of needles which reduced air movement and slowed drying. The thin plastic got torn up by fall winds, followed by heavy fall rains before the state fire folks would let me burn. Now they won't burn--too wet.
So now I have piles to cover again and hope they will dry out enough to burn come spring. But because of the way things are packed so tight, I don't really expect them to dry out enough to burn this season.
A friend who had the same problem took a loader & fluffed up the piles, giving more airspace and shaking down some of those needles. I've been wanting to move up to a tractor with a loader, but my long term needs are only for a tractor of about 20-25 HP (it's the size, not the power, really). I won't buy new for a tractor that I would only use 20 hours a year after this project is done.
Questions:
Anyone ever had this slash pile problem? How did you deal with it?
Would forks on the bucket help much to get in there & work over the piles?
Here are some currently available tractors:
1975 JD 830, $8,500 2wd
Ford 2600, $4,000 2wd
Ford N/H 1715, $9,500 4wd
JD 850, $6,500, 2wd
Ford 1720 with new loader & tires, 3,000 hrs., $10,000
Opinions as to suitability for this project? I would probably want to resell the JD 830 & Ford 2600 after the project was done as they are larger than I want long term.
Thanks for all your assistance.
RS
dangerdoc
11-27-2005 19:32:22
 Re: Help! Need to rework logging slash piles in reply to Richard Scott, 11-25-2005 15:04:30
I find that a good dry haybale soaked with about 1/2 gallon of diesel creates alot of heat and gets reluctant fires going. Lift a corner with a loader to get the bale under a significant amount of wood.
Richard Scott
11-27-2005 09:21:06
Thanks for all your replies. Unfortunately, I have tried most of the ideas suggested. Started the piles with old motor oil & they burned for a little while. Used a leaf blower to heat them up, they cooled down as soon as the blower was taken away. Tried a propane torch. Like the leaf blower, the fire cooled down as soon as the torch was taken away. The problem seems to be that there are so many needles they fill up all the air spaces & they seem to hold water like a sponge. When the fire goes out, you see a solid wall of needles and sticks.
At this point, I think plan C is to cover them again and try burning after a couple months more. If only the centers burn, then I'll need that loader to make new, smaller piles out of what is left.
A source of free plastic!: Plastic is expensive; it would cost about $400 for enough 6 mil plastic to cover my 42 piles. I have found a mobile home set up guy who will set aside the plastic he takes off the MH's & let me have it for free. Wish I had thought of this last summer.
Hal/WA
11-26-2005 20:51:33
Have you tried starting the fires with a propane torch? I use my Harbor Freight weedburner torch attached to a 5 gallon propane tank, and have had good luck getting pretty wet piles to burn. I push the burner into the pile and down low and let the heat do the job. Needles that are still on limbs burn great. Piled wet needles burn slowly and steam/smoke a lot, but eventually do burn. My biggest problems have been with piles that had a lot of dirt mixed in. They take weeks to burn.
I have used some of those cheap blue tarps on parts of some of my piles, to give an area of somewhat dryer fuel to get piles started. I also use my tractor and loader to stir the piles after they have burned down some. This exposes more fuel to the air and ends up taking much less time than just letting the piles burn.
If you can't get piles to burn using a propane torch, maybe you will have to wait until next year. It depends on how much precipitation you get. The blue tarps are often available for a couple of dollars on sale. I would suggest buying a few and partially covering some of your piles, so the rain will run off. In my experience, the bigger the pile, the better it will burn, so you might want to consider pushing piles together if the authorities will allow you to.
Years ago, we always put a junk tire in each burn pile. That always got them to burn....but now it is specificly prohibitted in my area. If they catch you burning tires, they not only can fine you, but I think they can revoke your burn permit. So I haven't burned tires for years. You might check what they say in your area. It works, but does make some black, very detectable smoke. It also leaves the nonburnable parts of the tires--the steel bead wires and steel belts as evidence.
Something else that works is moving actively burning material from a well-started pile with a tractor loader to a nonburning pile. It is a smoky job to do this, but is a way to get a second pile started.
Good luck! It has taken me years to get the mess cleaned up and burned after my 20 acres was logged. But that was mostly because the loggers didn't do what they promised and were really sloppy about piling the slash. I am not sure I would have had the logging done if I had known how much mess they would leave....live and learn.
Kporter
11-26-2005 08:17:45
Use a leaf blower and a small amount of diesel. Throw the diesel on and wait for a few minutes to let it run down into the pile. light it and give it heck with the leafblower... They will burn! If you are anywere near Dallas- I can help.
Joel Harman
11-26-2005 06:34:50
Accept the fact that you are going to sharpen the chain when you are finished...Run saw down middle of pile to collapse it. Do this about 2 or 3 times maybe 18" apart. this will collapse pile, mix used motor oil n gas. Just enough gas so you don't blow self up. set fire to "new pile" in middle of machine pile. then find small dry stuff & get weiners n marshmellows.
Midwest redneck
11-26-2005 04:08:12
Something I did when I cleared land to build my house. I hired a guy with a steel tracked excavator to bury the brush, it may cost you $70/hour to pay for a guy to bury it but no fire risk.
kyhayman
11-25-2005 19:15:49
Try renting an excavator or tracked high lift. While not either one, I normally get a 550 Deere from Hertz for about $1300 including trucking for a week (40 hrs on the meter). They will deal with me and let me have it for 2 weeks if the time included Christmas and New Years for the same money.
RodinNS
11-25-2005 19:01:04
Mud is generally the limiting factor in burning brush piles. Some operators are good at piling, and some aren't.
When I'm setting a pile on fire, I start near some smaller material, use diesel oil to get it going good, plus I like to use a few old tires..... then fire the waste oil to it once it's hot enough..... Either petreoleum or vegetable based oil. I know the tires and oil are taboo in most places..... but they work. Then, if you have a good tight clean pile, that should get it going. If it's dirty, then all the oil in arabia won't make it burn. If worst comes to worst, then get the hoe back in and break the piles up, start a small fire, and then feed the piles to the fire. BT/DT.
Rod
ralph oregon
11-25-2005 18:12:23
where do you live?? ralph
Green B
11-25-2005 17:37:56
If you are neer Medford Biomass one may come and chip them for free HTH.
Coldiron
11-25-2005 16:52:34
Richard, Make up a good burn fan at a cost of probably 250.oo or buy a new one for about 600.00 +. If you have a pretty good access to a part of the pile where you could throw in small limbs and enough cord wood to start a good sized fire get her burning. I start my fires with a propane torch with the flame at about 1/2 full open valve. Usually doesn`t take more than 20 min to get her going. Sit the fan in a position to push the flames into the burn pile and get set to adjust the pile as needed to keep her going. Now is the best time to burn with the wet weather when the fire cant get away from you. I am burning two piles right now. I am using an 8N with a Wagner Loader with loaded tires, rear wheel weights and tire chains. She does a great job packing the piles about 20 feet in dia. to keep them burning. The cage, propeller, engine and frame should be fairly easy to find and put together. I built my fan about 8 yrs ago and it still works great. Just be careful that you dont roll your pile over on it like a lot of guys do. LOL
wayne2
11-25-2005 16:09:52
I'm thinking you could get an excavator w/operator and in short time bust up slash set it afire when burns down rechink. Last part I did with a 30 ford. wifes stupid horse was no help-talk bout stuff washing off when i hit the shower!!! still have leather gloves i used certain things do not change even after 20-25 yrs. Luck Wayne
Fred P
11-25-2005 16:24:57
 Re: Help! Need to rework logging slash piles in reply to wayne2, 11-25-2005 16:09:52
There are two or three ways to burn them. They may burn right now. Dig under one of them and get a fire started and it may burn. Some wet piles that I burned a few years ago, I got an excavator in, We started a fire between two or three piles and then added to it from the other piles. After the fire is burning you can not put fuel on fast enough with an excavator or log loader. Or cover them next summer and burn them when the first rains come in October. I have burned shovel piled piles in October and had them gone in less than � hour.
Fred..... ..... ..
