Tractor Talk Discussion Forum
Tire Pressure
Hoosier JD
11-25-2005 07:59:04
I have a 4010 gas JD, I only use it to plow snow in the winter and rides for the kids in the summer. It has new tubes/tires with 16.9 on the rear, 11L 15 on the front, I believe that both are 6 ply. No extra weight on the back (8' blade on the back), 2 extra pads on the front. How much air pressure should I run in them? Right now I run about 18psi in the back and 50psi in the front. This seems to be doing alright. Just came up in conversation yesterday and now I'm not real sure. Any help would be appreciated. Mike
msb
11-25-2005 15:27:12
 Re: Tire Pressure in reply to Hoosier JD, 11-25-2005 07:59:04
35# is more than enough for the front tires.50# will give you some bounce you don't need especially during road travel.16-18# on the rear is about right.
Hoosier JD
11-25-2005 15:34:43
 Re: Tire Pressure in reply to msb, 11-25-2005 15:27:12
Thanks to you too,MSB. Mike.
Leland
11-25-2005 08:29:22
That is about what we run in the FIL's 4010 so just do what your doing .
Hoosier JD
11-25-2005 15:27:16
 Re: Tire Pressure in reply to Leland, 11-25-2005 08:29:22
Thanks Leland. Mike
