Tractor Talk Discussion Forum
Waterglass for block repair
Dan in Ore
11-24-2005 10:02:39
I have an F-12 that has a cracked block. Someone told me of a producet called Waterglass. Does someone know where I can get that item?
John M
11-24-2005 17:02:41
 Re: Waterglass for block repair in reply to Dan in Ore, 11-24-2005 10:02:39
I would be very leary of putting anything in the radiator of a F12 to fix a leak. Theres no water pump to pump the stuff around and itll basically just sit there. Blocks can be repaired in the area which I think youre talking about pretty easily by a professional welder with nickel rods.
Dan in Ore
11-26-2005 03:05:57
 Re: Waterglass for block repair in reply to John M, 11-24-2005 17:02:41
John,
This crack is on the inside. It is opposite of the spot that is always cracked, so welding is probably not a viable option. I was going to put in some of the threaded pins, but can"t find them. Some of the neighbors told me to put in the waterglass.
Thanks for the responses
Dan
John M
11-24-2005 17:02:44
T_Bone
11-24-2005 13:57:19
Hi Dan,
You can get sodium silicate from any pharmacy, Wal-Mart, Walgreens, etc: why I don't know as it's egg whites and you usually have to ask for it. About $5/pint
Use about 1/8 pint while the engine is running and warm. Careful as too much will quickly plug up the cooling system. It will mix with green anti-freeze but takes less. Takes about 1/2hr of circulating to seal the pin holes in the head gasket.
How a person can tell if sodium silicate has been added, is around the the filler neck there will white crystals.
How to tell a blown head gasket is to look for black carbon floaters or foamimg in the water .
T_Bone
Fred OH
11-25-2005 07:58:56
 Re: Waterglass for block repair in reply to T_Bone, 11-24-2005 13:57:19
I think water glass was originally used to put in the chicken water to make the egg shells harder. Fred OH
T_Bone
11-25-2005 09:17:29
 Re: Waterglass for block repair in reply to Fred OH, 11-25-2005 07:58:56
Hi Fred,
That's a new one...LOL
I know it's used as a glue to seal a cardboard boxs.
T_Bone
Bob
11-24-2005 13:42:31
Waterglass is sodium silicate.
A lot of stop-leak products, K&W Permanent Metallic Block Sealer, for one, contain sodium silicate as the active ingredient.
At the link below, in the "product" box, type in 401016-6 for more information.
