Tractor Talk Discussion Forum
cleaning mating surfaces
Eurlith
11-24-2005 07:08:19
What's the safest method when cleaning mating surfaces when putting the tractor back together? Especially the head gasket surfaces. I'm getting ready to sandblast some pieces to paint and figured that the mating surfaces need to be protected. However, how does one clean and smooth these surfaces?
ps Dell thanks for the info on removing hydraulic piston.
Chris(WA)
11-24-2005 10:53:44
 Re: cleaning mating surfaces in reply to Eurlith, 11-24-2005 07:08:19
I have a flat board sander that I use to dress the head and block with. Have to be careful not to get real agressive with it but it works well and is MUCH faster than hand sanding.
dave1
11-24-2005 10:25:57
Just wash the sheets
Eurlith
11-24-2005 09:33:57
I was thinking about steel wool. Has anybody tried that?
old
11-24-2005 09:37:08
 Re: cleaning mating surfaces in reply to Eurlith, 11-24-2005 09:33:57
Steel wool works ok if you have all the old gasket off but it doesn't do much to any gasket that might still be there. Thats why I use the wire wheel on a drill.
Eurlith
11-24-2005 09:52:21
 Thank you in reply to old, 11-24-2005 09:37:08
Thanks for the info guys.
EJR-IA.
11-24-2005 09:01:07
Before I put a new head gasket on, I spray the surfaces with ether and wipe with clean cloth.To get old gasket,dirt and rust I use a air right angle die grinder with roloc discs this works really great!
old
11-24-2005 08:44:53
My self I use a wire brush on a drill been doing it that way for decades
BillD1
11-24-2005 10:18:01
 Re: cleaning mating surfaces in reply to old, 11-24-2005 08:44:53
Brake cleaner to get rid of any grease or oil, Putty knife to scrape the old gasket, wire brush and die grinder also clean the studs at this step, Blow clean, another dose of brake cleaner and a clean shop rag wipe off May be overkill but have not had a head gasket leak yet
