Tractor Talk Discussion Forum
who sells v-8 chevy adapters for a farmall h
martind
11-18-2005 05:41:02
looking to put a 350 in a farmall h?anyone sell the adapter to attach the engine to the tranny?
bcPA
11-19-2005 19:32:35
 Re: who sells v-8 chevy adapters for a farmall h in reply to martind, 11-18-2005 05:41:02
I saw a h with a chev v8 near effort PA and another with a vw rabbit diesel in it near kutztown PA. So it can be done.
JoeIH
11-19-2005 09:47:47
Clem Sievert in Granger Iowa installed a 2.8 chevy motor in an H. Nice job. Also installed a 345 IH motor in a M. Also a nice job. You might try information and get his ph#.
ChadS
11-19-2005 07:39:08
Good Luck trying to put the chevy in the H bellhousing, The H is too narrow to fit it all in. You would have to move the 350 forward to make it all clear to have room for the starter. In the H"s, the best method I see, is to use a 4 speed cast bellhousing and bolt it directly to the H engine plate, use the input shaft out of the 4 speed, that has the shaft bearing inthe bellhousing, then adapt the Chevy shaft, to the H shaft. The you can use the chevy flywheel, clutch, well, all the chevy components and not have to do much customizing,, the front mounts will be a pain, the H rails are too narrow, but, you could get a set of frame rails from a 460, that would open things up quite a bit, then you can build stands to mount the front of the engine into the frame rails. its simple to bolt the bellhousing to the H engine plate, and hook up the clutch and input shaft, its fromthe bellhousing forward is where you run into the problems on space for accessories. Hope this helps, ChadS
