Tractor Talk Discussion Forum
year of ford tractor
Gene Welch
11-17-2005 04:02:25
I bought this purty little ford I was told it was an 1952 8n the serial no. dose not match up as far as I can see,ser.# on my tractos is 200328*.
I was looking at history it said that 9n and 2n han a front mount dist. and in1948 the 8n had a side mount dist, my old beauty has a front mount dist. now I'm not sure if I have a 2n or 8n could someone please help me on this. GENE Tx.
Jim.UT
11-17-2005 12:51:12
 Re: year of ford tractor in reply to Gene Welch, 11-17-2005 04:02:25
Check the link below and you should be able to pin it down. Early 8N's all had front distributors. Side distributors appeared around mid-1950 if memory serves. The link will tell you for sure.
Sometimes these old tractors are just mutts, having been pieced together from several other tractors.
BillyinStoughton
11-17-2005 06:26:46
Early 8N"s can still have a front mount distributor, versus the later 8N"s that had the side mount. Since yours does have the 4 speed transmission, it is definitely an 8N. One quick way to tell an early 8N from a later is the presence of a proofmeter (or tachometer) on the lower right side of the dash. Only the later 8N"s will have the proofmeter. 8N"s were made starting in late 47" through 52"...so by using these clues you should be able to narrow it down. Hope this helps!
Tim...Ok
11-17-2005 04:38:29
All 9/2 and 8N motors are interchangeable,so it may have been swapped sometime,engine serial number is on 1x4 square boss just below head gasket,in front of starter.. 9/2N's had 3 speed trannys,8N had 4 forward speeds..9/2N's have big bolt pattern wheels,8N's have small pattern..there is an actual date stamped on alum. cover on bottom of differential,this may help to date the rest of the tractor..
Tim
Gene Welch
11-17-2005 04:50:18
 Re: year of ford tractor in reply to Tim...Ok, 11-17-2005 04:38:29
thank you Tim ,I have 4 speed small pattern on wheels the stamped number I can't read the first letter but the other three are ?179 I found the serial number wich read200328* thanks again gene,tx.
Tim...Ok
11-17-2005 05:53:02
 Re: year of ford tractor in reply to Gene Welch, 11-17-2005 04:50:18
Look at the date on the bottom of alum. hydraulic pump under differential.. it will have a date stamped like 5-12-48 these are not commonly changed out so it should tell ya when the pump was made,tractor was probably assembled a few weeks or months later..
Tim
Gene Welch
11-17-2005 06:04:59
 Re: year of ford tractor in reply to Tim...Ok, 11-17-2005 05:53:02
thanks Tim I'll check this out gene
Tim...Ok
11-17-2005 06:17:57
 Re: year of ford tractor in reply to Gene Welch, 11-17-2005 06:04:59
Gene, I went back and read your original post again,all 1948 8N's were front dist. models..I think they changed to side mount in late 49 for the 50 models..
Tim
Gene Welch
11-18-2005 03:23:58
 Re: year of ford tractor in reply to Tim...Ok, 11-17-2005 06:17:57
Tim you were right I found the year on the bottom of trans case it was built on 7-1-49 thank you.
I want to say thanks to everyone who responed, this is a great site.gene uinlan Tx.
