Tractor Talk Discussion Forum
W6 Engine removal
Kevinm3
11-16-2005 02:04:23
Can someone out there offer some guidance on the removal of the engine of a W6 McCormick? Everything is out of the way and 2 bolts at the bell housing end have been removed, also the two nuts at the front end. I can get the front end to raise a small amount but the back end doesn't budge. Are there any other bolts to remove? The shaft between the motor and the gearbox has been disconnected at the yoke and the clutch thrust bng sleeve mounting is undone. What next? Thanks.
John M
11-16-2005 03:23:17
 Re: W6 Engine removal in reply to Kevinm3, 11-16-2005 02:04:23
There are two dowels, one on each side, at the back of the engine.The look like a boken off bolt.Ge tthe right sized nut and run them down on the dowel to get them out,just keep running them down until it comes out.
